recovery on timer expiry for R2
Oct 24th, 2007
Can anyone tell me how to increase the value of the timer for R2 connection that my calls wouldn't get dropped after 6 seconds of inactivity.
Thanks in Advance.
Paolo Bevilacqua Wed, 10/24/2007 - 05:26
  • Hall of Fame,
    Founding Member
Does the call connects then drops after 6 secs ?
Or which kind of inactivity are your referring to?
It is happening for incoming or outgoing calls ?
It is possible that something is not correct with the E1 R2 "handshake" as applicable to your country/telco, hence the call drop.
surenx_cisco Wed, 10/24/2007 - 05:36
The log in gatekeeper shows a duration of 6 seconds but a call doesn't get established. This doesn't happen to all calls only to some of them and each of those unsucessful calls show 6 sec duration and 102 disconnect cause code.
This is happening for incoming calls
Here's the config in my Cisco 3640
controller E1 0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled
cas-custom 0
alert-wait-time 20
the last line alert-wait-time was added not long ago but it doesn't help either.
I think I need some solution like this http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094487.shtml which advices to increase the value of timer T310 but in my case when I connect via R2 it seems that there's no option to increase the timer value.
Thanks in Advance
Paolo Bevilacqua Wed, 10/24/2007 - 05:41
  • Hall of Fame,
    Founding Member
you would need a trace of "debug vtsp signal" to understand why the call fails on the R2 side.
Notably your config does not specify a custom contry/telco, so it's possible that in its genericness does not meet in some case what the switch expects.
