Cisco 3750 stack problem
Oct 24th, 2007
i have a switch on a stack that seem not be respond anymore. i tried to restore it to factory default (after removing his stack cables) pressing the mode button. Is there another way to restore it to factory defaults? model is a ws-c3750g-48-ts-e
MUHAMMAD SHAHEEN Wed, 10/24/2007 - 11:13
  • Silver, 250 points or more
To restore this switch to factory default, you can do following 3 steps
Log into the switch using Console
#del vlan.dat
#rease nvram:
#reload
the switch should return to factory default
Shaheen
andreagentile71 Thu, 10/25/2007 - 02:27
switch was in fault, we will change it.
was not possible to see the console prompt anyway.
thanks for your help
