unified messaging install first timer
Oct 24th, 2007
Can anybody anser a simple question for me. I'm about to run the schema update on a system, once the update is run are there any visible signs that everything has completed ok. Do any extra fields appear in the user setup?
pklos Wed, 10/24/2007 - 06:29
No, those fileds are hidden. You can watch then using ADSIEdit.
regards,
pk
