Upgrade UCC Express 4.5 servers from a MCS-7825-I2-CCX1 to a 7835
Oct 24th, 2007
We have a UCC Express with the server above. Now we need to upgrade to a bigger server due to a contact center expansion.
I did not find any document in Cisco.com about this subject.
Overall Rating: 3 (1 ratings)
antonio.vazquez Wed, 10/24/2007 - 06:06
  • Bronze, 100 points or more
Is it only a hardware migration?
What is exactly the model of 7835 servers?
antonio.vazquez Wed, 10/24/2007 - 06:10
I think, that you should export the configuration from the old server 7825-I2 and import that configuration in the new server (7835) using BARS application. Really, it's a software reinstallation.
Regards.
pfavamedidata Wed, 10/24/2007 - 06:21
I will use the MCS-7835-I2-CCX1.
It will be a hardware migration followed by 18 seats add-on, but the seats add-on is not a problem.
antonio.vazquez Wed, 10/24/2007 - 08:04
then you should install the software in the new server and restore a backup from the old server using BARS like I tell you in a my last post. I supose that you'll install the same software version in the new and in the old servers, won't you?
If my message helps you please rate it.
Antonio
