HP NIC Teaming Native VLAN issue
Oct 24th, 2007
Hi, I'm trying to set up a trunk connection to a HP Server. All the VLAN NIC's on the server get proper DHCP addresses except the Native VLAN (I know for sure that the DHCP of the Native VLAN works fine). When I debug the DHCP server, I see that it receives a DHCP request and it sends an offer back on VLAN1.
So my guess is that the communication from the server to the switch works fine, but communication in the opposite direction doesnt. I think that the NIC teaming software doesnt allow traffic for the native vlan to be received untagged.
Anyone any idea's?
Config of the switchport to which the server is attached:
SW_AL_01#show int faste 0/23 switch
Switchport: Enabled
Administrative mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: 1,10,20
Pruning VLANs Enabled: 2-1001
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Self Loopback: No
aghaznavi Tue, 10/30/2007 - 13:25
If the trunk does not pass specific VLAN traffic, the issue can potentially be that the VLAN has not been added in the database. Issue the vlan database privileged EXEC command in order to enter VLAN configuration mode. From this mode, it is possible to add, delete, and modify VLAN configurations for normal-range VLANs. Could you please specify which switch and what os ( IOS or CAT OS) ie cisco switch series or non cisco switch you are using .
