PIX 501 Port Forward
Oct 24th, 2007
Hello all,
I am having a problem with port forwarding on my 501. This is what I have entered:
static (inside,outside) tcp interface https 172.17.x.x https netmask 255.255.255.255 0 0
access-list acl_outside permit tcp any interface outside eq https
access-group acl_outside in interface outside
I am running 6.3(5)
The firewall is basically factory defaults, I have configured 1 ezvpn and is essentially the only use of this firewall, so I don't think that will cause a problem, but who knows.
Here is my running config.
PIX501# show run
: Saved
PIX Version 6.3(5)
interface ethernet0 100full
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname PIX501
domain-name ----
clock timezone MST -7
clock summer-time MDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 209.x.x.x 255.255.255.240
ip address inside 172.17.x.x 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 172.17.x.x 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 209.x.x.x 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
ntp server 129.6.15.28 source outside prefer
http server enable
http 172.17.x.x 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 172.17.x.x 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
vpnclient server 216.x.x.x
vpnclient mode client-mode
vpnclient vpngroup ---- password ********
vpnclient username ---- password ********
vpnclient enable
terminal width 80
Cryptochecksum:********
: end
Thanks a million.
Patrick Iseli Wed, 10/24/2007 - 10:14
  • Gold, 750 points or more
The configuration is good. This is not the problem.
1.) Has your webserver the PIX IP as default gateway ?
2.) what do you see in the logs when you try to connect from the outside.
# shows log from the PIX buffer
show log
# enables logging to the buffer
logg on
logg buff info
3.) Have you cleared the translation table after changing the static ?
clear xlate
Note that this will reset all connections.
sincerely
Patrick
