Remote access using Robotics modem
Oct 24th, 2007
Hi,looking for advice to connect to various 1700,2500,&3600 series routers via dialup. I get window, but no prompt. I've done following:
. changed cable (router to modem)
. reset options on modem
. rebooted router and modem
. cleared line aux 0
Any ideas, would appreciate the help.
felixarrow1 Wed, 10/24/2007 - 10:13
Here is config:
line aux 0
password xxx
autobaud
script startup aux
login
modem InOut
transport input all
flowcontrol hardware
CLI output on AUX 0:
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns
1 AUX 2400/2400 F inout - - - 0 0 0/0
Line 1, Location: "", Type: ""
Length: 24 lines, Width: 80 columns
Baud rate (TX/RX) is 2400/2400, no parity, 2 stopbits, 8 databits
Status: No Exit Banner
Capabilities: Autobaud Full Range, Hardware Flowcontrol In,
Hardware Flowcontrol Out, Modem Callout, Modem RI is CD
Modem state: Idle
Modem hardware state: CTS* noDSR DTR RTS
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:10:00 never none not set
Idle Session Disconnect Warning
never
Hyperterm is set at 8,N,1 tried various speeds from 2400 - 38400
