Troubleshooting
Oct 24th, 2007
Which three of the following indicate a problem of physical layer? I am not sure about the 'excessive ethernet collisions' and 'router serial line encapsulation failure'. Anyone can help? Thanks.
router serial line down----physical
router serial line protocol down -------Data link
switch port link light is off-----physical
excessive Ethernet collisions ----?
router serial line up, no CDP neighbors----data link
dialup authentication failure-----data link
router serial line ecapsulation failure----?data link?
Overall Rating: 4 (1 ratings)
LordFlasheart Wed, 10/24/2007 - 11:16
I would say that excessive ethernet collisions would be a physical layer issue, duplex vs half-duplex for example. The serial line encapsulation is data-link as you would define encapsulation protocols at the data-link layer (e.g. PPP, HDLC, Frame Relay etc).
HTH,
Chris
