FTP passive or active
Oct 24th, 2007
Hi all. I have an issue where a 1750 using IOS 12.1.3(XT2). I have client software on the LAN side that creates an FTP connection, authenticates, then disconnects without transferring any files.
I called the company and they stated that it could be an ftp "active/passive" issue. Can anyone shed any light on why I would need to make adjustments to my config?
Overall Rating: 5 (1 ratings)
a.cruea1980 Wed, 10/24/2007 - 13:54
Because active FTP connections use a random port for data transfer, but passive uses port 20, if I remember correctly.
It would probably be wiser to make the clients use passive FTP than to change your router around to try and get connections through.
Frank Hoeben Thu, 10/25/2007 - 05:12
You've got it the wrong way around.
PASV uses a random >1024 port, while non-passive uses port 20 for data connections.
BOTH can be a pain to setup if the FTP server is unaware of being behind NAT.
slayerhawk Tue, 11/06/2007 - 14:26
Has anyone made this work? The clients on the LAN side use an active ftp session. I have used an access list that allows all tcp, ip, and udp to the host ip address.
