Global transport inside VRF
Oct 24th, 2007
I would like to setup a router like the following
int fa0
ip vrf forwarding inet
ip addr x.x.x.x
int t0
ip addr y.y.y.y
ip route vrf inet
Has anyone done this?
I know that the reverse works ok (you can transport VRFs in a GRE tunnel (VRF inside the tunnel, global IP routing outside on the GRE-layer).
Any help appreciated, thanks.
aronjsmith Wed, 10/24/2007 - 12:21
That's close, it doesn't address GRE/DMVPN interfaces, which don't follow the same rules.
In other words, a global GRE interface that uses a VRF interface as the 'tunnel source' interface.
