VPN 4.01 to 4.7 upgrage - "remove plugin failed"...
Oct 24th, 2007
I can't get client 4.01 to uninstall - continually getting "remove plugin failed". I have heard of a traffic108.msi file that can fix the problem but I can't find that file anywhere. Cisco's manual uninstall procedure didn't work either. Thoughts?
sadbulali Tue, 10/30/2007 - 14:00
It sounds like you attempted an install with the Microsoft installer without installing the previious version of the client.
