DHCP debug
Answered Question
Oct 24th, 2007
I am having an issue with DHCP. I am using a cisco 1710 (one fastethernet and one ethernet) on my network. I live in an apartment where my ISP provides me a direct ethernet line to them. Everyone in the appartment gets an ethernet line. The ISP runs a DHCP server and supplies everyone at the appartment with their own IP.
Recently, I turned on the dhcp service to provide addresses to my LAN. A couple days later my ISP blocked my connection saying I was giving out IP addresses on their network. From what I can tell, my router is receiving requests but not handing out IPs. I'm not sure if by seeing the traffic if it does any responses at all. From what they[ISP] have told me, the router is seeing the DHCP requests but not giving anyone an IP. However, this is causing other computers on the network to not get an IP at all. All need to figure out what the issue is. The following is my configuration with comments and the debug. Any help would be highly appreciated.
Debug:
The 208.x.x.180 is the DHCP assigned address to my ethernet (WAN) port.
Router#debug ip dhcp server events
Router#debug ip dhcp server packet
*Apr 7 17:10:00.507: DHCPD: DHCPINFORM received from client 0100.0ae4.d408.97 (208.x.x.82).
*Apr 7 17:10:00.507: DHCPD: Finding a relay for client 0100.0ae4.d408.97 on interface Ethernet0.
*Apr 7 17:10:00.507: DHCPD: Seeing if there is an internally specified pool class:
*Apr 7 17:10:00.507: DHCPD: htype 1 chaddr 000a.e4d4.0897
*Apr 7 17:10:00.507: DHCPD: remote id 020a0000d02df1b400000000
*Apr 7 17:10:00.511: DHCPD: circuit id 00000000
*Apr 7 17:10:00.511: DHCPD: there is no pool for 208.xx.xx.180.
*Apr 7 17:10:03.511: DHCPD: DHCPINFORM received from client 0100.0ae4.d408.97 (208.x.x.82).
*Apr 7 17:10:03.511: DHCPD: Finding a relay for client 0100.0ae4.d408.97 on interface Ethernet0.
*Apr 7 17:10:03.511: DHCPD: Seeing if there is an internally specified pool class:
*Apr 7 17:10:03.511: DHCPD: htype 1 chaddr 000a.e4d4.0897
*Apr 7 17:10:03.511: DHCPD: remote id 020a0000d02df1b400000000
*Apr 7 17:10:03.511: DHCPD: circuit id 00000000
*Apr 7 17:10:03.511: DHCPD: there is no pool for 208.xx.xx.180.
*Apr 7 17:10:23.003: DHCPD: checking for expired leases.
*Apr 7 17:11:18.047: DHCPD: DHCPINFORM received from client 0100.0ae4.d408.97 (208.x.x.82).
*Apr 7 17:11:18.047: DHCPD: Finding a relay for client 0100.0ae4.d408.97 on interface Ethernet0.
*Apr 7 17:11:18.047: DHCPD: Seeing if there is an internally specified pool class:
*Apr 7 17:11:18.051: DHCPD: htype 1 chaddr 000a.e4d4.0897
*Apr 7 17:11:18.051: DHCPD: remote id 020a0000d02df1b400000000
*Apr 7 17:11:18.051: DHCPD: circuit id 00000000
*Apr 7 17:11:18.051: DHCPD: there is no pool for 208.xx.x.180.
Configuration:
Router#show run
Building configuration...
Current configuration : 1117 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ip dhcp use vrf connected
ip dhcp pool internal_DHCP
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 38.9.212.2
ip cef
ip name-server
interface Ethernet0
description =====WAN=====
mac-address
ip address dhcp hostname
ip access-group 101 out
ip nat outside
ip virtual-reassembly
half-duplex
no keepalive
fair-queue
no cdp enable
interface FastEthernet0
description =====LAN=====
ip nat inside
speed auto
ip route 0.0.0.0 0.0.0.0 208.x.x.1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Ethernet0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 101 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router#
Correct Answer by bbayer about 9 years 2 months ago
I have never seen a router hand out addresses for the wrong network before.
I think you need to block inbound DHCP requests on your Ethernet0 interface. If I were you I would also set up the IOS firewall on your Ethernet0 interface. Try pasting this into your router: (you will need at the advanced security feature set)
conf t
int e0
no ip access-group 101 out
exit
no access-list 101
access-list 101 permit udp any eq bootps any eq bootpc
access-list 101 deny ip any any
ip inspect name FW http
ip inspect name FW ftp
ip inspect name FW udp router-traffic
ip inspect name FW tcp router-traffic
int e0
ip inspect FW out
ip access-group 101 in
no fair-queue
end
wr
This should allow your router to get a DHCP address from your provider and prevent your neighbors from seeing ANYTHING on your network.
Brian ": )
CCIE #14105
Overall Rating: 5 (1 ratings)
Correct Answer
bbayer Thu, 10/25/2007 - 22:32
conf t
int e0
exit
no access-list 101
int e0
ip inspect FW out
no fair-queue
end
wr
Brian ": )
CCIE #14105
pcexhaust Sat, 10/27/2007 - 07:22
Thank you for your reply. I have added your configuration to my router. When I enable the same debugging as before, I only get:
*Apr 8 11:52:47.550: DHCPD: checking for expired leases.
*Apr 8 11:54:47.550: DHCPD: checking for expired leases.
*Apr 8 11:56:47.550: DHCPD: checking for expired leases.
So, it looks like the issue is fixed!
