3750 Enhanced Image DHCP issue
Oct 24th, 2007
Might have a couple of faulty switchports on a stack of 3750 enhanced image switches. Have any of you run into something similar???
Issue: 3 ports out of 48 are not relaying client DHCP requests. All the ports belong to the same VLAN 20 and have the same configs and they all work correctly except 38,39,&40. Port 41 works correctly. If I static the clients, they have connectivity (pings successfully). Any ideas?
interface GigabitEthernet1/0/38
switchport access vlan 20
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface Vlan20
description USER
ip address 10.45.240.1 255.255.255.0
ip helper-address 10.45.195.21
ip helper-address 10.45.195.22
