Issues with ASA and VLAN
Oct 24th, 2007
Hello.
I am having communicaton issues between a router and ASA 7.2(2) with subinterfaces. A simple ping from ASA can not reach the router. Here is the config:
****** BEGIN ******
! ASA
int eth0
no shut
int eth0.40
vlan 40
nameif outside
no shut
! SWITCH
int f0/1
descrip **** ASA eth0
sw trunk encap dot1q
sw trunk native vlan 40
sw mode trunk
int f0/2
descrip *** Router E0
sw mode access
sw access vlan 40
! ROUTER
int f0/0
ip address 192.168.1.2
no shut
****** END ******
I enabled "debug arp". When I do a ping from ASA to R1, on ASA I can see the outgoing ARP packets. On R1 I can see the incoming ASA-ARP packets as well as the R1-ARP-REPLY BUT on SW I can only see the ASA-ARP-REQUEST packets to R1; never the R1-ARP-REPLY packets.
Scenario 1: If I disable the subinterface on the ASA and enable just ethernet0 without vlan, the ping works fine.
Scenario 2: If I do the following change, the ASA can reach R1:
int eth0.40
ip address 1.2.3.4 255.255.255.0
int eth0
nameif xxxx
Any advice is welcome.
Overall Rating: 5 (1 ratings)
greivin.viquez Thu, 10/25/2007 - 12:48
TO DOCUMENT THIS CONVERSATION FOR OTHERS OUT THERE:
I found the problem.... AN ASA BUG. I red the bug id "CSCsj96350". The bug is for ASA5505 however I followed the workwaround... and it worked for my 5510. So If the switch port where the ASA is connected, has the same "trunk native vlan id" as the "vlan id" of the ASA, the ASA WILL NOT TAG them....having no communication on such network.
I tested on 7.2(2) but nothing else.
JORGE RODRIGUEZ Thu, 10/25/2007 - 13:37
  • Green, 3000 points or more
Greivin, thanks for posting your own solution, it is great to share this info, I just happened to buy asa with code 7.2.2 but have not run into issues yet, I therefore rate..
Rgds
Jorge
