LMS 2.6 Bundled Ciscoview doesn't support Cisco C10008 (PRE3-RP)
Oct 24th, 2007
R10k8-GDI-BRAS07#sh ver
Cisco IOS Software, 10000 Software (C10K3-P11-M), Version 12.2(31)SB7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 22-Aug-07 12:56 by pwade
ROM: System Bootstrap, Version 12.2(20061016:191909) [fyang-rom-1_3 101], DEVELOPMENT SOFTWARE
R10k8-GDI-BRAS07 uptime is 1 day, 23 hours, 39 minutes
Uptime for this control processor is 1 day, 23 hours, 39 minutes
System image file is "disk0:c10k3-p11-mz.122-31.SB7.bin"
Cisco C10008 (PRE3-RP) processor with 1933311K/163839K bytes of memory.
SB-1 CPU at 800Mhz, Implementation 0x401, Rev 0.2, 512KB L2 Cache
Backplane version 1.0, 8 slot
Last reset from power-on
PXF processor tmc0 is running.
PXF processor tmc1 is running.
PXF processor tmc2 is running.
PXF processor tmc3 is running.
1 FastEthernet interface
6 Gigabit Ethernet interfaces
7039K bytes of non-volatile configuration memory.
125440K bytes of ATA compact flash in bootflash (Sector size 512 bytes).
500472K bytes of ATA compact flash in disk0 (Sector size 512 bytes).
Standby is up
Standby has 2097152K bytes of memory
Configuration register is 0x102
I installed Ciscoworks LMS 2.6 Bundled and the package update Rtr10000.cv50.v10-0.zip. Everything was successfully but when I used ciscoview to display the Cisco 10008 chassis the error display: "http://192.168.2.5:1741/CVng/uii/blank.htm
Message
Can't find applicable device package for 192.168.2.6.
Cause
Device package for this device type is not installed or device support for this device type might not be available or you are attempting to open a component inside a device.
Action
Please install a device package for the device type or open the parent device to manage the component."
Another issue is I couldn't use RME Software Image Management for this router
Please help me to figure out the issue.
Thank you in advance,
Brian
Joe Clarke Wed, 10/24/2007 - 19:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The PRE3 is not yet supported by CiscoView. Package version 10.0 for the C10K only supports the PRE1 and PRE2 modules. The same is true for RME SWIM. I currently do not have an ETA on when this route engine will be supported. You should probably open a TAC service request to get that information.
