IPCC Authenticate a User for a Call/ or Redirect
Oct 24th, 2007
Hi all,
I am planning to add a sub flow on my IPCC Queuing Script, for Afterhours.
This part of the Script will be used to Authenticate a User by a PIN or Password, and if the PIN is correct to Transfer them to a Particular Number or if they fail to Authenticate then to Redirect them to a Local Voice mail.
I am looking for a sample Script or a Way to do this; your help will be much appreciated. Thanks
Overall Rating: 5 (1 ratings)
mnour401917_2 Thu, 10/25/2007 - 22:43
Baseer
Thank you very much for the response. I have it working in my LAB, and i think i should be able to successfully add it in our call Centre.
The Only problem is, it is only one PIN used to authenticate, Is it possible to use more than one PIN or Passwords to Authenticate.
Mohammed
Chavdar_Baramov Mon, 10/29/2007 - 08:51
Yes you can use as many PINs as you like - Just add anouther script one level deeper in your IVR.
lpinder Tue, 11/06/2007 - 05:04
What version of CRA are you using to create this script.
I am using 3.5(3) and am unable to open it.
Thanks in advance,
Lee
