cat 6500 problem on 10b port
Oct 24th, 2007
I have upgraded catalyst 6500 IOS to new version (s72033-ipservicesk9-mz.122-33.SXH.bin) and than, all the module SFM-capable 48-port 10/100 Mbps RJ45 have some strange problem.
The ports on the module will have many input errors, and CRC; the server behind the ports also will lose real connection to the network. However, if you do “show int status” on the cat6500, it still connected, and if you log into the server (which linked to the port) on console, it still recons the connection available.
I have also found I can easily fix the problem by shut/noshut on the port. But, the problem will occur later. And also, there is always some CPU intensive sometime before with no reason.
Could anyone give me some tip what problem it is? And what I can do with the problem?
Any comments will be appreciated
Thanks in advance
lamav Wed, 10/24/2007 - 19:04
Hi.
It sounds like you have a duplex mismatch problem as a result of autonegotiation.
Do one of two things:
1. Hardcode both the server NIC and the switch port for speed and duplex (example: 100/full or 1000/full).
2. Set both the server NIC and the switchport to "auto". Sometimes, though, the server NIC's autonegotiation protocol may have added proprietary features that the Cisco switch does not support -- and that may cause both sides to lose sync when the periodic renegotiation takes place. The industry has had a problem standardizing the Autonegotiation protocol.
Victor
lamav Wed, 10/24/2007 - 19:06
Oh yeah, never set one side of the connection to "auto" while hardcoding the other side. It only works if you are dealing with a Gigabitethernet, otherwise you will have a duplex mismatch.
julxu Thu, 10/25/2007 - 01:30
I have no good luck.
the server is as5200, configure as:
interface Ethernet0
ip address 10.1.1.1 255.255.255.0
no ip redirects
no ip directed-broadcast
no ip route-cache
no ip mroute-cache
the port on cat6500:
interface FastEthernet9/4
description as5200
switchport
switchport access vlan 196
switchport mode access
wrr-queue bandwidth 20 100 200
wrr-queue random-detect max-threshold 3 90
wrr-queue cos-map 1 1 0
wrr-queue cos-map 2 1 1 2
wrr-queue cos-map 3 1 3 4 6 7
mls qos vlan-based
spanning-tree portfast
before the cat6500 is hardcoded, and I have changed to auto 4 hours before, now, the problem came back.
Any advice?
Julie
lamav Thu, 10/25/2007 - 03:52
can you post the speed and duplex seetings for the server and switch?
julxu Thu, 10/25/2007 - 16:05
There is no actually configuration for speed and duplex for the ports. By default, it is auto. so, the setting on both are auto, am I right? Also, there is no speed/duplex related configure in globel.
cat6500 sh int
FastEthernet9/4 is up, line protocol is up (connected)
Hardware is C6k 100Mb 802.3, address is 0013.1a04.8903 (bia 0013.1a04.8903)
Description: caracalla
MTU 1500 bytes, BW 10000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Half-duplex, 10Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:32, output 00:00:43, output hang never
Last clearing of "show interface" counters 1w0d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
142018 packets input, 105758743 bytes, 0 no buffer
Received 3200 broadcasts (3169 multicasts)
72481 input errors, 64295 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
144305 packets output, 45555226 bytes, 0 underruns
0 output errors, 9 collisions, 4 interface resets
as5200 show int
Ethernet0 is up, line protocol is up
Hardware is Lance, address is 00e0.1e88.7769 (bia 00e0.1e88.7769)
Internet address is 10.2.2.2/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, rely 255/255, load 1/255
Encapsulation ARPA, loopback not set, keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 1/75/125/0 (size/max/drops/flushes); Total output drops: 0
Output queue 0/40 (size/max)
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 1 packets/sec
393597 packets input, 251894293 bytes, 70 no buffer
Received 64658 broadcasts, 0 runts, 0 giants, 125 throttles
15 input errors, 0 CRC, 0 frame, 0 overrun, 15 ignored, 0 abort
623309 packets output, 223481043 bytes, 0 underruns
9 output errors, 259 collisions, 256 interface resets
0 babbles, 0 late collision, 500 deferred
9 lost carrier, 0 no carrier
#sh int statu m 9
Port Name Status Vlan Duplex Speed Type
Fa9/4 caracalla connected 196 a-half a-10 10/100BaseTX
Many Regards
julxu Thu, 10/25/2007 - 17:16
Just add something.
And also, it seems cat6500 lost MAC address of the server first.
