LMS patching - resolved, pls remove.
Answered Question
Oct 24th, 2007
Hi Folks,
How can I tell what patches (rme, cm, common services etc) have been installed on a LMS 2.6 server? Software Update shows me application versions, but I want to see what patches have been installed.
Cheers, Steve.
Resolved....
Can't see the forest for the trees - just realised I click on the product name and it drills down into patching details etc.
Correct Answer by Joe Clarke about 9 years 6 months ago
Under Software Update, click on the application name. The patches should be visible there under "Patches Installed".
Overall Rating: 3 (1 ratings)
Correct Answer
Joe Clarke Wed, 10/24/2007 - 19:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
stevek1 Wed, 10/24/2007 - 20:00
thanks Joe, my brain cells were out to lunch for a few minutes - I had it sorted just after I posted it. Tried to delete the post but you have to request this from the moderator. Anyway, you were spot on as always. Cheers....Steve.
