korbenda11as Wed, 10/24/2007 - 22:58
can you send me the configuration. Actually the problem is I'm planning to setup router to act as terminal server and connect other router using serial for frame-relay connection. However, my other routers dont have serial. This is just for a purpose of lab. can you give any advice of the best approach?
t511820 Fri, 11/02/2007 - 02:24
Using a crossover cable will solve your problem..
Hieu
