isakmp - pix506e
Oct 25th, 2007
When I transfer the text of my old pix's configuration to a text file, the "isakmp key" doesn't come out, all I see is "*********". I am in the "config t" mode. Can you show me how. I have a full access of my old Pix506e. Thank you.
Peter
Overall Rating: 5 (4 ratings)
pjhenriqs Fri, 10/26/2007 - 01:47
I tried out both solutions on a PIX506E. The tech-support does not work but the TFTP server does.
Thanks! I also had the need to do this today.
Paulo
pjhenriqs Thu, 10/25/2007 - 08:05
I don't know if this is true for all PIX/ASA versions but in some you can go into the ASDM/PDM and check the pre-shared key (for some reason it's not encrypted on the web interface).
Not sure that this is the case with you.
pjhenriqs Fri, 10/26/2007 - 04:23
It turns out that the TFTP functionality is a Cisco bug.
It makes sense that they fix it since TFTP is not safe. So, in the future, just remind your passwords because there won't be anyway to recover them it seems.
Paulo
