Available address for subnet...
Which two of the addresses below are available for host addresses on the subnet
192.168.15.19/28? (Select two answer choices)
A. 192.168.15.17
B. 192.168.15.14
C. 192.168.15.29
D. 192.168.15.16
E. 192.168.15.31
F. None of the above
Answer: A, C
According to new CCNA exams, (subnet zero) is Answer B also correct.
Since it has subnet boundary of 0,16,32,48, etc
so broadcast will be 15, 31, 47
Kevin Dorrell Thu, 10/25/2007 - 01:42
  • Green, 3000 points or more
No. The address they have given is 192.168.15.19/28, in other words the subnet that runs from 192.168.15.16 to 192.168.15.31. Option B, 192.168.15.14 is not in that subnet. OK, option B is a valid host address if you allow subnet zero, but not in this subnet.
Kevin Dorrell
Luxembourg
xs_echoss Thu, 10/25/2007 - 08:48
cuz they already gave the subnet which 192.168.15.19 falls in, 192.168.15.16, only A,C are correct.
