CSS - Packet trace
Answered Question
Hi sirs,
I need to know if someone can help me with the meaning of the options of the flow options command under the llama (debug) mode. On the CCO I found only the 0x103, are there other options? What's their meaning?
Thx
davide
Correct Answer by Gilles Dufour about 9 years 6 months ago
there is none.
The CSS does not offer this functionality.
The ACE module does.
Gilles.
Overall Rating: 5 (1 ratings)
Gilles Dufour Thu, 10/25/2007 - 05:09
  • Cisco Employee,
CSS11503-2(debug)# flow options ?
00000020 Trace Route Changes
00000010 Simulate DOS Attack
00000008 Trace Spoof List
00000004 Trace Source IP Address
00000002 Trace UDP Flows
00000001 Trace TCP Flows
Gilles Dufour Tue, 10/30/2007 - 04:24
  • Cisco Employee,
I feel like you're trying to find a way to log an entry for each connection you get.
Some logging functionality.
We do not recommend to use the flow trace for that.
This is a debugging tool, and should only be used to trace issues and should be turned off once the problem has been resolved.
Gilles.
Correct Answer
Gilles Dufour Tue, 10/30/2007 - 07:19
  • Cisco Employee,
there is none.
Gilles.
