EIGRP adress-family
pat1848
I've a question about EIGRP. If i configure an adress-familiy in EIGRP to route a vrf, it's not possible to configure two eigrp processes within this family.
I have two neigbors with different AS - how is it possible to redistribute this two processes within the same vrf(address-family)?
Any suggestion?
cheers
patrick
9 Replies 9
attrgautam
Level 5
Level 5
Patrick
I dont think it is possible - you may try configuring 2 different VRF(different RD) for both AS each running a different EIGRP instance for both and having the same route-targets. Not sure if it is elegant, but might just work. Please note that it should be a MPLS-VPN.
If I am correct(Honest, I am not sure) then the connectivity is through BGP and not exactly with EIGRP.
To add more details to get it working, you can configure a single instance if you like.
For eg, one global eigrp instance and then you can specify local AS just like in BGP for peering with different AS vrf's.
router eigrp 1
auto-summary
address-family ipv4 vrf A
network 10.1.1.0 0.0.0.255
no auto-summary
autonomous-system 10 <---- Local AS
exit-address-family
Now each vrf would be routed in its own domain, with any RD or RT.
If you have this challenge at one point and would like to get the routes across you can configure standalone BGP with no peerings.
Configure address-families for each VRF redistribute the respective eigrp into BGP and vice versa, import and export the RT. And you are set to go.
Here is a sample config to make the setup work.
ip vrf A
rd 100:1
route-target export 100:1
route-target import 100:1
route-target import 100:2
ip vrf B
rd 100:2
route-target export 100:2
router bgp 1
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf B
redistribute eigrp 20
no synchronization
exit-address-family
redistribute eigrp 10
no synchronization
exit-address-family
router eigrp 1
auto-summary
redistribute bgp 1 metric 10000 100 255 1 1500
network 20.1.1.0 0.0.0.255
no auto-summary
autonomous-system 20
exit-address-family
no auto-summary
exit-address-family
HTH-Cheers,
Swaroop
Hi Swaroop
I may have to admit, that i have just VRF Lite. It's probably in the wrong discussion forum. So there's no MPLS and i have just one VRF Instance which is peering to two EIGRP routers in different autonomous systems. I think it's not possible because i can't configure two autonoumos-systems in a adress-familiy.
cheers
patrick
You are right...This will not be possible without MPLS as you configure only one autonomous system. Unless you run 2 EIGRP instances like this
router eigrp 100
autonomous system 50
redistribute eigrp 40
router eigrp 200
autonomous system 40
But sadly this doesnt work, so you may need to turn on MPLS :(
Gautam, the sample config given does not need MPLS enabled on any interfaces neither LDP or VPNV4 BGP peerings.
And also as given in your config you cannot assign the same VRF to 2 Eigrp processes.
Patrick, From your first post I got it that you are trying to implement Vrf-Lite (without MPLS/LDP on any interfaces or MPBGP peering)
Thats the reason I gave a sample config to make things clearer. If you go ahead and implement the config as given modfying your VRF names and RT's and AS's it will just simply work, without MPLS enabled on any interfaces.
Give the config a try to avoid confusion.
HTH-Cheers,
Swaroop
Hi swaroop
I'm sorry i didn't recognize your solution for the first time... i just read quickly through... you are right, in this case it's possible..
I'll have a try
Thanks a lot
Sure Patrick, do give it a try...if there is any problem with the implementation i would be glad to help.
you would see the other EIGRP AS routes as external in each EIGRP AS with this method, which is consistent with what would have been achieved with redistrbuting different EIGRP AS routes into each other.
HTH-Cheers,
Swaroop
Swaroop
That was certainly new for me. Thanks. I went back to 4364 and this is what it told me
4.3.6. Route Distribution Among VRFs in a Single PE
It is possible to distribute routes from one VRF to another, even if
both VRFs are in the same PE, even though in this case one cannot say
that the route has been distributed by BGP. Nevertheless, the
decision to distribute a particular route from one VRF to another
within a single PE is the same decision that would be made if the
VRFs were on different PEs. That is, it depends on the Route Target
attribute that is assigned to the route (or would be assigned if the
route were distributed by BGP), and the import target of the second
VRF.
So it should work for Patrick.
Gautam,
What the 4.3.6 sections means is if 2 VRF are on a same PE then there is obviosuly no BGP running back to back to the same PE,
(No BGP peering from PE1 to PE1) so we cannot say that it is distributed by BGP (for eg: like in PE1 to PE2).
But Never the less the route distribution is totally dependent upon Route Targets (for which again BGP is required even though its standalone with no peerings) as the route distribution is dependent upon the assigned/configured route-targets and the import target in the other VRF on the same PE.
So we introduced a standalone BGP to make the RT function work and help distribute routes from one VRF to other.
(as the same VRF cannot be configured in 2 different EIGRP processes with different AS's)
I would be glad to clarfiy further, as much as i understand.
HTH-Cheers,
Swaroop
