eBGP maximum-paths
Oct 25th, 2007
Dear All,
For load balancing by using BGP we can use maximum-paths option. I want know that if we are doing BGP multihoming with different providers then maximum-paths option will remain valid or not ?
Mujeeb
Joseph W. Doherty Fri, 10/26/2007 - 17:46
Assuming you have a public AS and your different providers have public AS, then you can multi-path effectively if you have an internal private AS that sees your public AS routers.
Other, possibly easier, solutions would be to load balance to your BGP routers, internally, using multiple static routes, an IGP that load balances, or something like GLBP, or using OER.
