Telco sends digit after digit
Oct 25th, 2007
We have 100 numbers, from xxxx3600 until xxxx3699. The problem is, that when somebody call us, our Telco don't send the whole number. Once he can identify that the call is for us, they already send us the first digits and when the caller complets the number, the Telco sends us the rest of the number.
The problem is that the CCME doesn't wait until the last digit arrive.
Anybody a idea which parameter I have to configure or whick command I have to apply? It seems to be a timer or something like that...
We have a PRI E1 ISDN Line. Cisco 2821 with IOS 12.4-3g SP Services.
Thanks for your suggestions.
Paolo Bevilacqua Thu, 10/25/2007 - 05:24
Not sure you can have a telco to send enbloc just because it's contemporary. Sometime there are no alternatives, or they are not allowed to change parameters at user's request.
Remember, overlap is alway faster than enblock for keypad-dialed calls, in variable-length numbering plans. The two things are deeply interconnected. This way when a caller from home dials the last digit, he/can hear ringback right away and not wait annoying 3-4 seconds.
pblumenthal Mon, 10/29/2007 - 02:25
This is the actual config about the serial interfcae and dial-peer:
interface Serial1/0:15
no ip address
isdn switch-type primary-net5
isdn overlap-receiving T302 3500
isdn incoming-voice voice
isdn send-alerting
no cdp enable
voice-port 1/0:15
echo-cancel coverage 32
cptone IT
dial-peer voice 1 pots
translation-profile incoming incoming
translation-profile outgoing outgoing
destination-pattern 0.T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
port 1/0:15
I hope it helps to find a solution.
Paolo Bevilacqua Mon, 10/29/2007 - 04:20
can you configure "service timestamps debugs datetime msec" and take "debug isdn q931" together with "debug voip dialpeer" with "term mon" ?
But before you do that, please upgrade to either 12.4(17) or 12.4(11)XJ4 that has many ISDN bugs fixed.
