manage ASA 5505 across IPSec tunnel via ASDM
Oct 25th, 2007
I am having an issue managing an ASA5505 across an IPsec tunnel. I've enabled the inside management interface, but when I try and access via ASDM, I get an "unexpected end of file error".
I am using 8.02 and ASDM 6.02. I can access the command line via telnet across the IPSec tunnel. I can access the 5505 via ASDM from the local subnet.
Any suggestions anyone?
TIA,
Kevin
vkapoor5 Wed, 10/31/2007 - 10:22
  • Bronze, 100 points or more
The error "unexpected end of file" is normal if there is no data in the source table. Check you've the right "http" cmds to allow the connection from the client PC to ASA server.
