QoS Config Help
Oct 25th, 2007
Hi Experts,
I have an 1841's FE interface (CE router) connecting to a 7600's Gigabit interface. (PE router). The bearer will be locked to 10 Meg as per the customer's requrement. The link will carry Voice and Video traffic to other sites in the Customer's MPLS VPN.
The QoS requirement is to allocate 5 Meg of Voice and 3 Meg of Video on this 10 Mbps link.
Will the following work ? Or, do you suggest I use 'bandwidth' commands under class instead of policing.
I am assuming that the traffic with appropriate DSCPs will get into the higher queues (2 and 3, Q 4 is priority queue) as per the default DSCP-CoS mappings.
class-map match-any Voice
match dscp cs5
match dscp ef
class-map match-any Video
match dscp cs4
match dscp af41
match dscp af42
match dscp af43
class-map match-all System
match dscp cs6
policy-map QuestField
class Voice
police 5000000 125000 125000 conform-action transmit exceed-action drop
class Video
police 3000000 75000 75000 conform-action transmit exceed-action drop
class System
bandwidth percent 20
random-detect dscp-based
Both on the PE and CE, in the outbound direction ; --
interface GigabitEthernet 1/47
ip address 1.1.1.1 255.255.255.252
speed 10
duplex full
bandwidth 10240
ip vrf forwarding Quest_12345
max-reserved-bandwidth 100
Service-Policy QuestField out
interface Fast 0/0
ip addresss 1.1.1.2 255.255.255.252
speed 10
duplex full
bandwidth 10240
Service-policy Questfield Out
Cheers
Arav
lgijssel Thu, 10/25/2007 - 03:55
  • Red, 2250 points or more
Indeed my suggestion is not to use policing for this. As long as the link can accomodate the maximum bandwidth it is better to use the bandwidth or priority commands in the class map.
Policing will directly lead to dropped packets, using the class map config will merely result in best effort forwarding which I consider preferrable for real time traffic instead of dropping it.
If you are a service provider this might be different because you will also need to forward the resulting traffic on your network and you do not want the customer to exceed his SLA.
regards,
Leo
aravindhs Thu, 10/25/2007 - 04:03
Leo,
Thank you for your reply. How does this look ? Does the 'priority percent 50' reserve 50 percent of 10 Meg and put the packets in the priority queue ? The requirement is to set 3 Meg dedicated for the Video too.
class Voice
priority percent 50
class Video
bandwidth percent 30
class System
Also, the 7600 PE router is a Gig interface. I understand that setting the "speed 10" on the interface will limit the traffic to 10 Mbps and won't require any rate-limiting on the 7600 to 10 Mbps. How does it all sound ?
Cheers
Arav
aravindhs Fri, 10/26/2007 - 08:22
Many Thanks guys ! I will try it out and let you know how it turns out.
Cheers
Arav
Joseph W. Doherty Fri, 10/26/2007 - 18:17
LLQ really only has one queue, so splitting traffic into two classes, voice and video, only accomplishes placing a rate limiter on each. This is fine if you think there is a need to drop voice or video traffic that exceeds their caps but usually you want to avoid drops for such real-time traffic. The latter would be better accomplished by just having both in one combined class that defines 80%.
However, for real-time LLQ traffic that can be bursty, such as many videos are, you might want to insure you have some addition bandwidth headroom. A total of 80% for LLQ is a high percentage of the link. Recall reading Cisco recommending not to exceed 50%.
With regard to other traffic, you really don't need to define it, as it will fall into an implicit default class.
I like the idea of setting the interface to 10 Mbps rather than using a shaper.
PS:
Don't use WRED on your video traffic; generally avoid WRED for any non-TCP traffic.
