7204 through output
Oct 25th, 2007
We have 7204 vxr router with G1 prossesing card int.When we did through output test we are only getting 210M for TCP and 820M for UDP which is realy concerns, by Cisco it should be near 512M.
Any sugesstions ?
sh ver
IOS (tm) 7200 Software (C7200-JS-M), Version 12.2(14)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 27-Jan-03 23:28 by dchih
Image text-base: 0x60008BB0, data-base: 0x61898000
ROM: System Bootstrap, Version 12.2(8r)B, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-JS-M), Version 12.2(14)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
7200-CC-1 uptime is 1 year, 19 weeks, 1 day, 21 hours, 47 minutes
System restarted at 16:07:04 BST Mon Jun 12 2006
System image file is "disk2:c7200-js-mz.122-14.S.bin"
cisco 7204VXR (NPE-G1) processor (revision A) with 245760K/16384K bytes of memory.
Processor board ID 23672938
Unknown CPU at 700Mhz, Implementation 1025, Rev 0.2, 512KB L2 Cache
4 slot VXR midplane, Version 2.3
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
6 Gigabit Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
62976K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Paolo Bevilacqua Thu, 10/25/2007 - 06:49
if you connect the systems for TCP test directly without router, do you get a different result ?
mohammedrafiq Thu, 10/25/2007 - 07:30
when we replaced 7204 with 3750-G switch then its hits near a Gig.
mohammedrafiq Thu, 10/25/2007 - 10:16
The interface is clean on the router which we running test, however on other live router we do have overrunn errors incrementing.
mohammedrafiq Fri, 10/26/2007 - 05:37
Hi, Thanks for you help, we have resolved the issue by replacing 7204 with 3750 switch,
