How do I troubeshoot IDSM freeze/reboot
Oct 25th, 2007
Hi all
I have two IDSM2 in two 6500 running 6.0(3)E1. Both of these IDSM are rebooting several times per day. They are running at around 60-70% CPU set in promiscuous mode monitoring three VLANs filtered on two gigabit trunks each.
The only thing I see on the 6500s is "18150: Card in module 5, is being power-cycled off (Module not responding to Keep Alive polling)" just before they reboot.
Where do I start? Is there a crashinfo to collect?
The IDSMs were delivered as "refurbished" with 4.1 installed, I have since upgraded them to 5.1.6-E1 and then to 6.0(3)E1. Is this setup too much to handle for the IDSM?
Fredrik Hofgren
didyap Wed, 10/31/2007 - 10:29
  • Silver, 250 points or more
Can you provide the following:
What is connected to the IDS, configs,and a topology?
eweigl Thu, 01/17/2008 - 00:55
Hello Frederic,
I have exactly the same problem, the only difference: my IDS boots once a week.
I had opened a TAC case (SR 606916833). The problem will be solved with a new SW version in February (see bug CSCsj49640).
Regards and good luck,
Eckhard
hoffa2000 Thu, 01/17/2008 - 01:40
After some traffic and inspection tuning it seems to me that it was the amount of traffic that caused this problem for me. When I decreased the inspected traffic from vlans (some 500mbit/sec) to specific interfaces AND lowered the packet logging the IDSM stopped rebooting.
Still, a software update would be nice
/Fredrik
