VPN help needed
Oct 25th, 2007
I have an ASA5510 that I am trying to setup VPN on. I need to allow home users access inside our network. I have tried going thru the VPN wizard several times and just cannot seem to get it working. I am using the Cisco VPN client, latest verision.
I am enclosing the latest configuration which also has a show version at the end of it.
Any help would be greatly appreciated.
Overall Rating: 5 (2 ratings)
acomiskey Thu, 10/25/2007 - 06:59
Firstly, you always want your vpn pool to be different than your inside network.
access-list inside_nat0_outbound extended permit ip any 10.19.1.0 255.255.255.0
ip local pool VPN 10.19.1.100-10.19.1.254 mask 255.255.255.0
Also add..
crypto isakmp nat-traversal
Also, are you trying to vpn to the inside interface?
crypto map inside_map interface inside
crypto isakmp enable inside
srosenthal Thu, 10/25/2007 - 07:16
Thank you for your help.
I am at home and want to have VPN access to the inside networks.
Seth
acomiskey Thu, 10/25/2007 - 07:21
These lines should say "outside" as you are vpn'ing to the outside inteface of the asa.
crypto map inside_map interface outside
crypto isakmp enable outside
srosenthal Thu, 10/25/2007 - 07:32
I did correct the config with the commands you gave me.
I tried to connect with the VPN client and still cannot. I was curious about the pre-shared key. Am I supposed to enter that in the client somewhere?
Seth
acomiskey Thu, 10/25/2007 - 07:36
Yes. You need to enter the group name "VPN" and the pre-shared key or "password" under the group authentication section of the cisco vpn client.
attrgautam Thu, 10/25/2007 - 07:37
Yes you need to have the Pre-shared key in the VPN Client. When you enter the group in thE vpn cLIENT, the psk will be the password for the group..when the connection is successful you will get the username and password dialog where you key in your personal information.
Let us know if it works
srosenthal Thu, 10/25/2007 - 08:23
Ok, I did that and it still will not connect. The VPN client tells me
Secure VPN Connection terminated by the Client.
Reason 412: The remote peer is no longer responding.
I am also attaching the latest config.
Seth
acomiskey Thu, 10/25/2007 - 08:34
This works for me...
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA
crypto isakmp identity address
crypto isakmp policy 20
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
srosenthal Thu, 10/25/2007 - 09:04
Thank you, that worked wonderfully.
Now my next question is how do I setup for certain clients to access only certain networks?
Again, thank you very much.
Seth
acomiskey Thu, 10/25/2007 - 09:12
Will these users be part of the same tunnel group or will you create differnet tunnel groups for different classes of users?
srosenthal Thu, 10/25/2007 - 09:28
I guess they can be part of the same group, just different user names and networks accessed.
Seth
acomiskey Thu, 10/25/2007 - 09:41
This should help you some...
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080641a52.shtml
This will show you how to create a vpn-filter acl which can be applied to a tunnel group policy or individual user account.
The other option is to remove "sysopt connection permit-vpn". This will stop ipsec traffic from bypassing your interface acl's. Then you can simply write the access you desire in your outside access list.
srosenthal Thu, 10/25/2007 - 11:48
Thank you again for the help. I did figure out that all I needed to do was add and ACL and then add a user and apply that ACL to the user.
Seth
