Deleting or Renaming the AccountAction.csv in RDBMS synchronization
Oct 25th, 2007
Good morning all,
I am trying to finalize a process using the RBDMS Sync on Cisco ACS 4.1 SE. The process will get my AccountActions.csv file, but does not seem to want to rename it. I have the synch occuring every morning at 0300. I guess one question would be, if the file does not change, what will occur? I get an error like this;
Could not delete CSV file on FTP Server - may process same actions again. (The file may be in use).
I have set up the FTP server to allow deletion and renaming from this login.
Any help or direction would be appreciated.
darpotter Fri, 10/26/2007 - 03:12
I would schedule something to rename the account actions csv on the ftp server.. have it run at 04:00
That way you know it done. Otherwise ACS will simply process all the same actions again.
This is because RRBMS sync was designed to work with proper databases. There is a field to indicate a row has been processed, but csv files are read only thanks to the retarded Microsoft csv driver.
dpatkins Wed, 11/07/2007 - 13:25
Thanks Darren,
Actually, if you are using the Quick n Easy ftp server, there are options to do so. Also, I created an account on the FTP server the same as teh account used in the Synch and that seemed to do the trick. Thanks again for the advice.
