DB Maintenance Plan for IPCC??
Oct 25th, 2007
IPCC-x 4.05a
Is there any maintenance plan that we need to setup within the SQL db for best practice?
We use BARS for backup, but I do not any maintenance plan on the db itself.
Or does the Historical Reporting Configuration within the AppAdmin address the maintenance on db?
Trae
Overall Rating: 5 (1 ratings)
lpezj Fri, 10/26/2007 - 01:37
  • Gold, 750 points or more
Trae,
The historical database maintenace is planned on the AppAdmin HR Configuration. You can schedule some parameters as purge older data, or purge when the database has reached an aumount of space, etc.
Hope this helps,
Juan Luis
