wrr on a 3550 Catalyst
Oct 25th, 2007
Dear all,
which Feature Set I need to implement wrr on this box ?
Because i have 12.2(25)SEB4. Must I have another Version ?
No comand is working.
Thx for our support.
bye joerg
royalblues Thu, 10/25/2007 - 08:15
  • Green, 3000 points or more
Strange... the WRR queue is supported both on the SMI and EMI versions as well
can you post a sh ver from your switch
Narayan
joerg.micheel Thu, 10/25/2007 - 21:47
Hi ,
here it is.
Thx for your reply.
sh vers
Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(25)SEB4, R
ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWAR
E (fc)
BBS1 uptime is 3 days, 21 hours, 39 minutes
System image file is "flash:/c3560-ipservices-mz.122-25.SEB4/c3560-ipservices-mz
.122-25.SEB4.bin"
cisco WS-C3560G-24TS (PowerPC405) processor (revision C0) with 118784K/12280K by
tes of memory.
Processor board ID FOC0950Y07J
Last reset from power-on
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:16:47:C3:E4:80
Motherboard assembly number : 73-9708-04
Power supply part number : 341-0098-01
Motherboard serial number : FOC09491XUA
Power supply serial number : AZS0948056Y
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C3560G-24TS-E
System serial number : FOC0950Y07J
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT0943157A
Top Assembly Part Number : 800-26348-02
Top Assembly Revision Number : B0
Version ID : V02
CLEI Code Number : CNMW400ARB
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 28 WS-C3560G-24TS 12.2(25)SEB4 C3560-IPSERVICES-M
Configuration register is 0xF
