4400 4.1 rel tacacs+
Oct 25th, 2007
I have configured the wlc for mgmnt auth using tacacs+ but the wlc is checking the local db first. I have changed the priority order from radius to tacacs but my tacacs id,which works for other devices, does not work on the 4400. Question: Is there a way to change the order of the priority of the db. When I issue the command aaa auth the output shows the order of local first and then tacacs....is there a way through the cli to change the order so that tacacs is checked first and if the tacacs svr fails, the local db is used?
ivillegas Wed, 10/31/2007 - 07:33
For the purpose of management first the local database is checked . Only then Radius server is tried. This is because in case if the Radius server fails no one can login to the controller.
Trending Topics - Security & Network
