More Than one IP default-gateway
ankbhasi Thu, 10/25/2007 - 09:22
  • Cisco Employee,
Hi Mike,
No you cannot.
Ankur
Kevin Dorrell Thu, 10/25/2007 - 20:38
  • Green, 3000 points or more
No you cannot. But you could try putting the switch's own ip address as default-gateway. If you do that, I think it will ARP for everything, and if your routers are responding proxy ARP for the routes they have, everything should work.
Try it, and let us know if it works OK.
Kevin Dorrell
Luxembourg
