ASDM session timing out
Oct 25th, 2007
I am using ASDM to manage a ASA5510. I can access the unit and configure it ok. But after about 5 minutes, I have to close out ASDM and then reconnect to the ASA all over again.
Any suggestions?
westcare Fri, 10/26/2007 - 11:55
There should be a small red circle in the bottom bar that lets you re-sync to the firewall or in the "file" menu choose "Refresh ASDM with the Running Config..." I do have an issue with the ASDM logging droping out after about 10 minutes. The only way I can get the ASDM logging back is to close and relaunch the ASDM. I am assuming that I hit my buffer limit.
