6509 switch - Lost management capabilities
Oct 25th, 2007
I have a 6509 switch running vers 12.2.
I seem to have lost management to the switch ping/telnet access. The switch is working and i'm able to console. Does anyone know why, or how I can fix this?
Thanks.
arififtikhar Thu, 10/25/2007 - 17:33
You must have already checked your PC's LAN connection, haven't you?
Please look if the management vlan/IP is still there and operational. Check it's vtp status etc..
miheg Thu, 10/25/2007 - 23:43
If your manage you switch on a vlan interface check if you can define a port of the switch in the same vlan and connect a pc with an IP in the same range as the IP of switch to that port.
Cheers,
Michel
steve.busby Fri, 10/26/2007 - 03:30
Besides the VLAN access, have you checked for an ACL that could be blocking VTY access?
Steve
