CRS 5.0(1) Setup
Oct 25th, 2007
  • Bronze, 100 points or more
I am installing a Single Node UCCX5.0(1) and after uploading the license successfully, I click Next to the get to the Unified CM Configuration page. I enter the Unified CM Telephony Subsystem user and password, same for RmCm user/password. Enter NTP ip. Click Next, and then I just get a blank web page and nothing/nada.
When I login to the appadmin I am still prompted with the initial setup.
The CM Telephony user and RmCm user have been created on CallMgr, but I do not get prompted for System Parameters or Languages, etc.
What gives? Anyone offer an explanation?
I don't have CSA running and my IE has no blocking popups.
Is it a UCCX5.0(1) bugette or what???
Any help much appreciated.
Chris
PS. I reinstalled 5.0(1) - same thing.
The web page is refencing the sysparams page, but NOTHING is displayed!!??!!!
cogden Thu, 10/25/2007 - 14:40
Apparently this problem is because the license used for 5.0 here has no agent count.
So I am going back to Cisco licensing (roll the eyes) to try and get a valid license for the correct number of Prem Agents purchased by customer.
Chris Deren Tue, 03/04/2008 - 14:23
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I am running into the same issue, were you able to get it resolved?
Chris
cjhunt Wed, 10/01/2008 - 05:58
Yes - this definitely is a licensing issue.
I tried pulling a disk on the server, then installing a license code that had an agent count of 100. This then allowed me to complete the integration with CUCM.
So, back to Cisco for the license file whatever happened to [email protected] ?
It's a nightmare now with no apparently dedicated resource for license enquiries...
/Chris
Chris Deren Wed, 10/01/2008 - 06:57
  • Hall of Fame,
My issue in fact was a bug (dont have the DDTS handy). The issue is that the config wizard allows you to speciy more than 2 CTI Mgr servers, however only 2 are supported, I've entered 3 which resulted in blank rmcm page, as soon as I re-ran the wizard and entered only 2 servers I was fine.
Chris
