Overlapping NAT statements on ASA
Oct 25th, 2007
I'm having trouble with NAT.
This works:
static (Internal-201,ELI-External) tcp interface 3389 192.168.201.114 3389 netmask 255.255.255.255
This doesn't:
static (Internal-201,ELI-External) tcp MY_EXT_IP 3389 192.168.201.114 3389 netmask 255.255.255.255
Why wouldn't the second statement work? I'm positive that I'm typing in the correct external IP.
Edit: I'm guessing that it isn't working because the first statement has overloading and the second one doesn't.. so it doesn't know how to "get back to me" since I'm in a private network myself. If this is the reason why, then is there a way to have multiple nat statements re-directing me, depending on my source IP? (ie: if I RDP from home, it redirects me to .114, and if I RDP from work, it redirects me to .177)
sundar.palaniappan Thu, 10/25/2007 - 15:52
  • Green, 3000 points or more
Your 2nd statement should work too as it's doing static PAT as well.
Are you permitting MY_EXT_IP port # 3389 on the ACL applied on the ELI-External interface?
Sundar
JORGE RODRIGUEZ Thu, 10/25/2007 - 19:02
As Sundar said, apply acl to eli-external interface..
Here is a usefull link to follow the example, it should work.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708b4.shtml#intro
static (internal-201,ELI-External) tcp interface 3389 192.168.201.114 3389 netmask 255.255.255.255 0 0
static (internal-201,ELI-External) tcp interface 3389 192.168.201.177 3389 netmask 255.255.255.255 0 0
access-list ACL1 extended permit tcp host ExternalIP-1 host 192.168.201.114 eq 3389
access-list ACL1 extended permit tcp host ExternalIP-2 host 192.168.201.177 eq 3389
access-group ACL1 in interface ELI-External
