Transfer of call directly to voicemail
Answered Question
Oct 25th, 2007
Can someone provide a pointer for forwarding calls directly to someone's voicemail instead of ringing their extension?
-Shikamaru
Correct Answer by timmektrakarn about 9 years 5 months ago
Add a CTI RP with *XXXX and CallFwdALL to Voicemail
make sure your default voicemail profile has mailbox mask XXXX listed or this won't work.
Overall Rating: 5 (1 ratings)
Correct Answer
timmektrakarn Thu, 10/25/2007 - 18:27
mhurley131 Thu, 10/25/2007 - 18:28
You can set it up so that users can dial * before the extension to send it directly to voice mail. Just create a CTI route for *XXXX and forward all to VM.
