send multicast by two GRE tunnels
Oct 25th, 2007
Hello everyone:
I have a problem to mount two tunnels with multicast support, I have a server in the IP multicast video 192.168.1.123, group 224.1.1.1 and I must convey this to two multicast tunnels where there are several receivers. But do not get it, someone can help me with this?
Thank you for any help they can give me
pd: A diagram attached
version 12.4
hostname cisco2811
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip multicast-routing
voice-card 0
no dspfarm
username admin privilege 15 secret 5 $1$sFpN$SXXXXXXYo.KsE40
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel0
ip address 10.10.1.1 255.255.255.0
ip pim sparse-dense-mode
tunnel source Loopback0
tunnel destination 217.127.XXX.188
interface Tunnel1
ip address 10.10.2.1 255.255.255.0
tunnel destination 80.32.XXX.125
interface FastEthernet0/0
description INTERNAL_LAN$ETH-LAN$
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description WAN$ETH-WAN$
ip address 195.77.XXX.70 255.255.255.248
ip nat outside
duplex auto
speed auto
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 195.77.XXX.65
ip route 192.168.3.0 255.255.255.0 Tunnel0
ip route 192.168.4.0 255.255.255.0 Tunnel1
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip pim bidir-enable
ip nat inside source route-map salida-fibra interface FastEthernet0/1 overload
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 120 deny ip 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 120 deny ip 192.168.1.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 120 permit ip 192.168.1.0 0.0.0.255 any
route-map salida-fibra permit 10
match ip address 120
cjnwodo Fri, 10/26/2007 - 00:26
In the absence of the configs for the other 2800 I have a few questions/tips, which might help you:
I assume you have pim enabled tunnels on the other Cisco 2811 routers with loopback0 as the source and multicast globally configured [ip multicast-routing]
1) You are setup for PIM sparse-dence mode but I don't see any RP or mapping agent config. If you don't configure this on any of your routers, the network will treat the multicast group 224.1.1.1 as a dence mode group. It should still work albeit the traffic will be flooded everywhere initially, then pruned by those routers that have no members
2) You should have ip pim sparse-dense-mode configured on your loopback0 interfaces
3) Are you using Bi-dir? If not disable it on all routers with no ip pim bidir-enable
4) I hope you know that the static routes on the config you gave-
do nothing for your multicast traffic on that router. What you need to do on the other 2811 routers [192.168.4.254 & 192.168.3.254] is to configure ip route 192.168.1.0 255.255.255.0 tunnel . This will allow those router to perform their rpf to the tunnel interface.
5) Make sure you have ip pim sparse-dense-mode configured on the interfaces [192.168.4.254 & 192.168.3.254]of the other Cisco 2811s.
Check: show ip pim nei On each router should show that the router 192.168.1.254 has 2 neighbours whilst the other routers only have one neighbour [192.168.1.254]
Check: sh ip rpf 192.168.1.123 On the other Cisco 2811s [192.168.4.254 & 192.168.3.254] should show that their tunnel interfaces are the rpf for the source.
lidium.net Fri, 10/26/2007 - 02:21
HTH hello, thank you very much for your answer, and your suggestions, here attached configuration of two router, which is connected to the Sender multicast and one of the multicast receivers, two receivers are exactly the same.
You might be able to help shape the "RP" or "mapping agent config" because frankly not where to begin this task
Router 1: 2811- Connect to Multicast Sender
version 12.4
hostname cisco2811
no aaa new-model
ip cef
username admin privilege 15 secret 5 $1$sFXXXXXX.EReYo.KsE40
interface Loopback0
interface Tunnel0
interface Tunnel1
description LOCAL_LAN$ETH-LAN$
ip nat inside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
Router 2 2811 - Multicast Receiver
version 12.4
service password-encryption
ip cef
no ip domain lookup
username admin privilege 15 password 7 104CXXXXx13
interface Loopback0
ip address 4.4.4.4 255.255.255.255
interface Tunnel0
ip address 10.10.1.2 255.255.255.0
tunnel destination 195.77.XXX.70
interface Ethernet0
ip address 192.168.3.251 255.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address 217.127.XXX.188 255.255.255.192
ip nat outside
no ip route-cache
no snmp trap link-status
pvc 8/32
encapsulation aal5snap
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip route 192.168.1.0 255.255.255.0 Tunnel0
ip nat inside source route-map nonat interface ATM0.1 overload
access-list 100 permit ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 deny ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 permit ip 192.168.3.0 0.0.0.255 any
route-map nonat permit 10
Commands en cisco 2811 source multicast
cisco2811#show ip pim neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
S - State Refresh Capable
Neighbor Interface Uptime/Expires Ver DR
Address Prio/Mode
cisco2811#show ip rpf 192.168.1.123
RPF information for ? (192.168.1.123)
RPF interface: FastEthernet0/0
RPF neighbor: ? (192.168.1.123) - directly connected
RPF route/mask: 192.168.1.0/24
RPF type: unicast (connected)
RPF recursion count: 0
Doing distance-preferred lookups across tables
cjnwodo Fri, 10/26/2007 - 02:42
Firstly it looks ti me like your PIM is not working properly, because you have no pim neighbours.
Firstly, let's see if your tunnels work.
On Cisco2811[loop 2.2.2.2]: ping 10.10.1.2 & ping 10.10.2.2
lidium.net Fri, 10/26/2007 - 07:55
Hello cjnwodo:
Yes, both 10.10.1.2 as 10.10.2.2 not work, I have no experience in such tunnels through Loopback, because if the replacement "tunnel source Loopback0" with "tunnel source 195.77. XXX.70 "at all points, the tunnels work perfectly.
Any ideas?
cjnwodo Mon, 10/29/2007 - 10:55
It's ok to use the tunnel source as loopback0. The only caveat is that each router must be able to route to the loopback 0 of the other router.
Quick test: from cisco2811 [192.168.1.254] do the following: ping ip 80.32.xxx.125 source loopback0
IF this doesn't work then you need to make sure that both routers can route to the loopback address of the other.
