error messages in wlc syslog
Oct 26th, 2007
hello,
perhaps somebody can help me with these error messages i receive from the wlc:
Oct 26 09:07:21.073 apf_wme_utils.c:2640 APF-4-RCV_ACTION_FRM_WITH_CODE: Received Action frame with code 2 from mobile station 00:1D:A2:30:E7:4D
Oct 26 00:06:57.271 apf_80211.c:4950 APF-4-PROC_DOT11_MAC_MGMT_DATA_FAILED: Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored.
Oct 26 00:06:57.271 apf_wme_utils.c:2640 APF-4-RCV_ACTION_FRM_WITH_CODE: Received Action frame with code 2 from mobile station 00:1D:45:1B:D3:7A
Oct 26 00:06:57.272 apf_80211.c:4950 APF-4-PROC_DOT11_MAC_MGMT_DATA_FAILED: Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored.
Oct 26 00:06:57.272 apf_wme_utils.c:2640 APF-4-RCV_ACTION_FRM_WITH_CODE: Received Action frame with code 2 from mobile station 00:1D:45:1B:D3:7A
and the next block of messages:
Oct 26 09:41:25.603 1x_auth_pae.c:3127 DOT1X-6-CCKM_UPDATE: CCKM: 00:1b:d4:54:b0:ef. Parameter name: CCKM, Param value: 35.
Oct 26 09:41:25.643 iapp_socket_task.c:580 IAPP-3-MSGTAG015: iappSocketTask: iappRecvPkt returned error
Oct 26 09:41:30.573 1x_auth_pae.c:3127 DOT1X-6-CCKM_UPDATE: CCKM: 00:1d:45:1c:0b:d2. Parameter name: CCKM, Param value: 4.
Oct 26 09:41:30.617 iapp_socket_task.c:580 IAPP-3-MSGTAG015: iappSocketTask: iappRecvPkt returned error
Oct 26 09:41:32.931 1x_auth_pae.c:3127 DOT1X-6-CCKM_UPDATE: CCKM: 00:1b:d4:58:e8:d5. Parameter name: CCKM, Param value: 37.
Oct 26 09:41:32.986 iapp_socket_task.c:580 IAPP-3-MSGTAG015: iappSocketTask: iappRecvPkt returned error
Oct 26 09:41:39.537 1x_auth_pae.c:3127 DOT1X-6-CCKM_UPDATE: CCKM: 00:1d:45:1b:d3:7a. Parameter name: CCKM, Param value: 8.
Oct 26 09:41:39.701 iapp_socket_task.c:580 IAPP-3-MSGTAG015: iappSocketTask: iappRecvPkt returned error
Oct 26 09:41:42.034 1x_auth_pae.c:3127 DOT1X-6-CCKM_UPDATE: CCKM: 00:1d:a2:30:e7:4d. Parameter name: CCKM, Param value: 24.
Oct 26 09:41:42.140 iapp_socket_task.c:580 IAPP-3-MSGTAG015: iappSocketTask: iappRecvPkt returned error
Oct 26 09:41:44.908 1x_auth_pae.c:3127 DOT1X-6-CCKM_UPDATE: CCKM: 00:1d:45:1c:0b:d2. Parameter name: CCKM, Param value: 5.
Oct 26 09:41:44.986 iapp_socket_task.c:580 IAPP-3-MSGTAG015: iappSocketTask: iappRecvPkt returned error
these two message blocks are repeated all over the time. we are using one wlc-4404, two acs and about 80 1131ag lwapp access points at the moment.
firmware release is 4.1.185. the 7921's are using the firmware 1.0.4. we are using eap-fast for the 7921 phones.
best regards,
joerg
edit from my side:
the message: "Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored." appears every time when there is an incoming call for a pick up group, which is configured on the 7921's phones.
irisrios Thu, 11/01/2007 - 06:50
  • Silver, 250 points or more
Messgaes in Block 2 is due to IAPP. IAPP is the protocol used for AP to AP communication and also by CCX clients for management communication. There is a known issue with Intel clients were they send the incorrect length in the IAPP packets they send to the controller. Upgrade the client software.
Trending Topics - Security & Network
