CSS - Simple configuration does not work
Oct 26th, 2007
See configuration details and some show commands below:
Client PCs can ping the virtual ip address of 10.253.1.101, but can not http to it.
Client PCs can http to the individual web servers on their ip addresses:
http://10.253.10.108:8180/ and http://10.253.10.109:8180/ .
Any idea what I am missing here?
Thanks in advance for your help
Mohan
ip route 0.0.0.0 0.0.0.0 10.253.1.14 1
!************************* INTERFACE *************************
interface 1/1
bridge vlan 253
interface 1/2
bridge vlan 173
!************************** CIRCUIT **************************
circuit VLAN173
ip address 10.253.10.240 255.255.255.0
circuit VLAN253
ip address 10.253.1.240 255.255.255.0
!************************** SERVICE **************************
service LB_Test_1
ip address 10.253.10.108
active
service LB_Test_2
ip address 10.253.10.109
active
!*************************** OWNER ***************************
owner LBTest1
content Web_Servers_Test1
add service LB_Test_1
add service LB_Test_2
vip address 10.253.1.101
vip-ping-response local-remote
protocol tcp
port 8180
active
end of buffer.
CSS11503# sh interface 1/1
Name ifIndex Type Oper Admin Last Change
1/1 3 ge Up Enable 10/25/2007 07:36:08
CSS11503# sh interface 1/2
1/2 4 ge Up Enable 10/25/2007 07:36:08
CSS11503# sh service
Services (3 entries):
Name: LB_Test_1 Index: 1
Type: Local State: Alive
Rule ( 10.253.10.108 ANY ANY )
Session Redundancy: Disabled
Redirect Domain:
Redirect String:
Keepalive: (ICMP 5 3 5 )
Keepalive Encryption: Disabled
Last Clearing of Stats Counters: 10/25/2007 07:36:17
Mtu: 1500 State Transitions: 0
Total Local Connections: 2 Total Backup Connections: 0
Current Local Connections: 0 Current Backup Connections: 0
Total Connections: 2 Max Connections: 65534
Total Reused Conns: 0
Weight: 1 Load: 2
Weight Reporting: None
Name: LB_Test_2 Index: 2
Rule ( 10.253.10.109 ANY ANY )
Redirect Domain:
Redirect String:
Last Clearing of Stats Counters: 10/25/2007 07:36:20
Total Local Connections: 3 Total Backup Connections: 0
Total Connections: 3 Max Connections: 65534
Weight: 1 Load: 2
CSS11503#
Overall Rating: 5 (2 ratings)
Gilles Dufour Fri, 10/26/2007 - 01:42
what's the default gateway of the servers ???
Make sure the response from the servers goes back to the CSS.
One trick is to configure client nat
ie:
group client
vip address 10.253.10.239
add destination service LB_Test_1
add destination service LB_Test_2
active
Gilles
sathappan Sat, 10/27/2007 - 01:34
In the services also, you need to add you port number 8180 .
with regards
sathappan.s
Gilles Dufour Tue, 10/30/2007 - 05:58
the port number is not required.
You need it only if you want to do port translation and use a different port on the servers then on the vip.
Gilles.
mp5766_2 Thu, 11/01/2007 - 04:29
Thanks Giles. That worked like a charm. I think you deserve a rating of 5 as you even provided the actual commands, in fact I did not even have to type them out, I just copied and pasted them line by line.
Sorry to get back to you this late. I was busy on another project and this was put on the backburner.
I have a related question, if I may ask:
Firstly when I attempt to run my application through the web interface, I can bring up the application login screen without a problem.
However I have to enter the details twice “enter the network password for site 10.253.1.101” (this is the content switch VIP). If I enter the User Name and Password a second time I can then login to the application.
(This is a Windows 2000 PC running IE 6.0.2800.1106).
For the purposes of Load Testing my application I have a number of machines installed within our test network (10.253.1.x)
These machines have Windows 2003 Server R2 with SP2 installed.
Again I can bring up the login screen for the application and I have to enter the User name and Password twice before getting any further.
Unfortunately at this point the application becomes unusable as required JSP files fail to be downloaded from the Server.
I'm currently looking at various settings within IE 6 (Security, Pop-Blockers, Proxy Server configuration.) to try and overcome this.
Do you have any thoughts on why I need to enter the User name and password twice?
Mohan
Gilles Dufour Thu, 11/01/2007 - 05:11
Mohan,
you probable need stickyness.
Try to add the following commands under the content rule.
url "/*"
advanced-babalnce arrowpoint
Gilles.
mp5766_2 Fri, 11/23/2007 - 07:31
Now I am testing some advanced configurations and my following configuration is not working.
Relevant configuration of 1 one of the CSS as follows:
service LB_Test_1
active
service LB_Test_2
active
owner LBTest1
content Web_Server_Test1
advanced-balance arrowpoint-cookie
protocol tcp
port 8180
url "/prweb/PRServlet/*"
active
content Web_Server_Test2
vip address 10.253.1.102
protocol tcp
port 8280
active
CSS11503# show rule
Content Rules:
///\\\ The Duke of Url.
{ O--O }
Name: Web_Server_Test1 Owner: LBTest1
State: Active Type: HTTP
Balance: Round Robin Failover: N/A
Persistence: Enabled Param-Bypass: Disabled
IP Redundancy: Master
L3: 10.253.1.101
L4: TCP/8180
Url: /prweb/PRServlet/*
Redirect: ""
TCP RST client if service unreachable: Disabled
Rule Services & Weights:
1: LB_Test_1-Alive, S-1
2: LB_Test_2-Alive, S-1
Name: Web_Server_Test2 Owner: LBTest1
L3: 10.253.1.102
L4: TCP/8280
Redirect: ""
end of buffer.
CSS11503#
CSS11503# show rule-summary
VIP Address Port Prot Url CntRuleName OwnerName Stat Idx
10.253.1.101 8180 TCP /prweb/PRServlet/* Web_Server_Tes LBTest1 Act 0
10.253.1.102 8280 TCP /prweb/PRServlet/* Web_Server_Tes LBTest1 Act 1
CSS11503#
I have tried launching a browser and connecting via the two load balanced URL's
http://10.253.1.101:8180/prweb/PRservlet
http://10.253.1.102:8280/prweb/PRServlet
Neither of these links currently work - I get a 'The page cannot be displayed' error message
However, I know that all four Tomcat nodes are up and working as I can login to the PRPC application via any of the direct links;
http://10.253.10.108:8180/prweb/PRServlet
http://10.253.10.108:8280/prweb/PRServlet
http://10.253.10.109:8180/prweb/PRServlet
http://10.253.10.109:8280/prweb/PRServlet
The above configuration works by modifying the url statement from
to
url "/*"
Mohan
