1751 WAN compression module
Oct 26th, 2007
Which module can i use to compress data on my two 1751 routers connected via 64 k diginet line(to be upgraded).
And where can i find this, i'm based in South Africa.
Aubrey
paolo bevilacqua Fri, 10/26/2007 - 03:19
  • Hall of Fame,
    Founding Member
There is no compression module for the 1750, and you don't need one with a line only 64 kbps.
Just enable software based compression, good luck!
Hope this helps, please rate post if ti does!
paolo bevilacqua Fri, 10/26/2007 - 03:20
  • Hall of Fame,
    Founding Member
