BGP - question about exam simulator
Oct 26th, 2007
hi there,
regarding the exam simulator in 642-661 for preperation, I wonder:
- do I have to reinitial BGP session with neighbor, after correction (clear ip bgp soft in)
- do I have to save run config? what command is supported ?
thanks for for an answer
Chris
Danilo Dy Fri, 10/26/2007 - 20:03
Do it as in the real world. If you make changes that will affect incoming BGP updates, execute "clear ip bgp neighbor_address soft in". If you make changes that will affect outgoing BGP propagation, execute "clear ip bgp neighbor_address soft out". Then save.
Some simulators have limitations that doesn't allows you to do any of the above. Its either the programmer who did the simulator is lazy or they just want you to change the config.
Some simulatiolators doesn't allow you to save by "wr mem" but "copy running-config startup-config", so when you do a save, make sure you try both commands.
Dandy
