NAC - GUEST VLAN
Oct 26th, 2007
Today, in the newest versions of IOS, the guest vlan is just for devices that don't speak EAP. With this user of Windows XP, for example, they don't enter in Guest VLAN (because Windows XP speak EAP!!). How do I do for the users guest be addressed for GUEST VLAN??
tstanik Thu, 11/01/2007 - 10:16
  • Bronze, 100 points or more
You can disable EAP on Windows XP to make the users able to enter the guest Vlan. Other option would be to use Windows 2000 inplace of XP.
