Cisco View Device Manager
Oct 26th, 2007
is there anybody who can tell me how to bring the Cisco View Device manager for 6500er up? I've installed the CVDM V.1.1 in the bootflash of my 6500er, IOS version is 12.2(18)SXF4 enterprise services. Installed java on the client is v.1.4.2_06. After launching the CVDM whithout proxy settings the windows starts gathering information, after a few seconds it stops with an error "java.lang.NullPointerException". This failure appeared with Mozilla 2.0.0.8 and IE 6.0, on the 6500er all vty lines are idle. Is anybody here who can help to solve the problem?
smahbub Thu, 11/01/2007 - 11:30
  • Silver, 250 points or more
The CVDM is not supported on the Supervisor 32 engine.
With Supervisor 720, the workaround is to downgrade the Cisco IOS? Software Release to 12.2(18)SX
ssieger Fri, 11/02/2007 - 03:17
Meanwhile i've received a patch for the CVDM, now it works fine, thank you.
ashiliwala Mon, 12/31/2007 - 05:41
I am having the same problem. You mention that you received a patch which fixed the problem. Can you tell me what this patch is & where I can download it from.
Thanks. . .
ssieger Thu, 01/10/2008 - 07:28
Here the text from the readme file; try to get the zip-file via the Bug-Id:
09-December-2005
This patch provides fix for the following bug:
CSCsc10956 - CVDM 1.1 does not work with 12.2(18)SXF
SUPPORTED IOS VERSION:
12.2(18)SXF
SIZE:
5,593,057 Bytes
DOWNLOADING AND MOVING FILES TO TFTP SERVER:
cvdm-c6500-1.1-CSCsc10956.zip contains the following two files
* cvdm-c6500-1.1.tar and
* cvdm-c6500-1.1_K9.tar (for Cisco IOS Cryptographic software)
Unzip cvdm-c6500-1.1-CSCsc10956.zip and copy one of the tar files to a TFTP server
Make sure to enter filenames exactly as they appear; (filenames are case-sensitive).
TRANSFERRING FILES TO YOUR SWITCH:
Step 1 : Access the switch CLI using a Telnet connection or the console port.
Step 2 : Transfer the files from the TFTP server to the bootflash of the switch. Issue
the following command:
# archive tar /xtract tftp:// / bootflash:
where is the filename of the CVDM-C6500 tar file you want to install
and is the IP address of the TFTP server. Make sure to enter filenames
exactly as they appear (filenames are case-sensitive). Make sure you are not in
configuration mode when issuing the archive command.
Step 3 : If you are not in configuration mode, issue the following command:
# configure terminal
Step 4 : Set HTTP server and path. For example:
# ip http path bootflash:
Please refer cvdm-c6500-1_1_readme.pdf in http://www.cisco.com/cgi-bin/tablebuild.pl/cvdm-6k for
further details on CVDM-C6500.
