quick image upgrade question
Oct 26th, 2007
It's been a very long time since I've done a image upgrade but when you do get the new image downloaded to the switch while it's live, you have to reload it for the new image to take effect? Also, it doesnt wipe out the config in nvram does is? I know they are both in two different memories but I want to be sure.
Thanks.
Richard Burts Fri, 10/26/2007 - 06:51
Matthew
Yes you must reload the switch to get it to run the new image. And no the reload and code upgrade will not wipe out the existing config.
Rick
