Firewall authentication from ACS
Oct 26th, 2007
I have Pix firewall which configure AAA to ACS. I have Also ACS 2.3 in Sun based.
I create two group in ACS. in group A has user like jon, sam bin and group B has user like shn , kell. now I permit autentication user group A to firewall. from group user A can suceesfully authentication Firewall and other device like router switch.
But problem is user of group can authenticate access level 1 in Firewall but can not authenticate other device like router or switch.
so it is bug ?. or how group B user can not access to router, switch but access to Firewall.
Thanks Biplob
ebreniz Thu, 11/01/2007 - 11:33
If the you are able to authenticate to firewall then its no problem with ACS. check the ACS config for the users access level privileges. Also add the user gruop B in ACS to permit the users of that group to aceess the routers.
