joepapesh Fri, 10/26/2007 - 09:23
It depends on how your Paging is configured, but when I have trouble like that I do these 3 things...
Reset device from Call Manager
Reset Paging Controller (Hardware that interfaces with Audio Equipment)
Do a Shut and No Shut of the FXO port that my paging controller connects to.
Good Luck,
--Joe
Kelex000333 Fri, 10/26/2007 - 09:26
I cannot locate any devices pertaining to a "page". I did reset analog gateway - no help.... where is the paging controller and FXO port done? I am remote and will need to walk through tech onsite.
joepapesh Fri, 10/26/2007 - 10:15
When you reset the gateway what device was it located in? The FXO ports I use are in our 3845, so to shut/no-shut I would login to the 3845 Router, and configure that port. The paging controller is a little harder to find, but to reverse engineer you could trace back the cable coming from Cisco device (that you just reset) to where-ever it connects. It more than likely is a couple of wires that go into an electronic box that also connects to the audio equipment.
Kelex000333 Fri, 10/26/2007 - 10:38
Cisco IAD2400 - but no access number of 399 i will trace it back and see. would rebooting the cm servers help? do I need to also reboot unity and what order?
joepapesh Fri, 10/26/2007 - 10:43
I wouldn't reboot the servers, because that shouldn't add any value...
mattcalderon Fri, 10/26/2007 - 10:45
  • Silver, 250 points or more
Look at your route patterns. A route pattern more than likely was made to take those digits and send them to a gateway. Once you find the pattern, look at the gateway it is supposed to go to and then log into the gateway and reset the voice port.
Kelex000333 Fri, 10/26/2007 - 12:26
I don't see anything with route pattern of 499. And nothing in route pattern pertaining to paging....weird. anywhere else? Would it not be an analog?
mattcalderon Fri, 10/26/2007 - 14:08
Do you dial the extension 499 from an IP phone or from an analog phone? The pattern does not need to be there if in your situation a dial-peer wil l be sufficient.
Kelex000333 Mon, 10/29/2007 - 05:04
From an ip phone. I restarted the gateways after-hours and works....thanks
joepapesh Mon, 10/29/2007 - 08:11
Glad to hear you were able to resolve the issue...
Kelex000333 Tue, 10/30/2007 - 12:26
Now having same issue. I found the device which is ATA 186 overhead paging. I have restarted/reset and still rining. where can this equipment be (ie. near the callmanager server, switch,)
joepapesh Wed, 10/31/2007 - 04:55
The ATA 186 can be located anywhere on your network similar to an IP Phone. The easiest way to track it down would be to locate the switchport it is connected to via MAC Address, and then trace that cable through your network. You could also try tracing back the analog phone line from the paging controller to the ATA.
Here is a page with a picture of the ATA, so you know what you are looking for...
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_data_sheet09186a008007cd72.html
--Joe
